3.9 ECU on 3.5?
NRS91
Hey guys
i was just wondering if a 3.9 ecu will work on a 3.5??
if so would i be looking at any power increases?
would is bring the 3.5 on lpg closer to standard?
and i would like to know where i could get an ecu extension loom?
In a pinch it probably would, assuming you're meaning swapping a 3.5 Hotwire ECU for a 3.9 Hotwire ECU, or flapper for flapper. The flapper and hotwire are not interchangeable with each other as there were changes to the injectors and rather obviously the ECU plugs are different.
Hell no.
Nope.
Buy some wire, some heatshrink, and some solder is probably the easiest option.
I'll rather predictably say MegaSquirt is probably a more suitable answer to your problems.
i meant lpg power...
and i had heard that using a 3.9 ecu would bring power increases...
what are the main differences between 3.5 and 3.9 ecus?
ive seen one the same type as mine for sael thats why i ask
And I meant "no", if your LPG system is running incorrectly I'd look at your LPG system, not the original ECU.
Well, it would probably bring a mixture of over-fuelling and occasional under-fuelling.
Like-for-like, one will have the correct fuel map for a 3.5 and one will have the correct fuel map for a 3.9.
