crazyfarmerboy Posted September 16, 2008 Share Posted September 16, 2008 hello i have been offered a rocky mountain overdrive for £420. this works the same way as a fairey as it is operated by a lever. my td5 is used fir towing and has a low ratio but when not towing i want some speed is this a good deal or is it better to pay more for a gkn. the rocky has done 14,000 miles from new and it has been on a TD5. cheers hope to hear soon. Quote Link to comment Share on other sites More sharing options...
western Posted September 16, 2008 Share Posted September 16, 2008 you won't find a new from GKN od now they ceased production recently due to far to many warranty claims, mines been fine bought 2nd hand from a fellow LR owner, But Devon4x4 may have a few left in stock, worth a e.mail/phone call.as the RM unit has been fitted & had use I'd say you have 2 choices buy the RM overdrive or fit the 1.22:1 high range transfer gear instead. Quote Link to comment Share on other sites More sharing options...
BigSi110 Posted September 17, 2008 Share Posted September 17, 2008 The RM overdrive gives a 27% increase in gearing, which you may find too much. The 1.22 gears give a 15% increase which, in my experience, is sufficient unless you want to run at 90mph all day. Quote Link to comment Share on other sites More sharing options...
Prith Posted April 17, 2009 Share Posted April 17, 2009 The RM overdrive gives a 27% increase in gearing, which you may find too much.The 1.22 gears give a 15% increase which, in my experience, is sufficient unless you want to run at 90mph all day. Does the RM Overdrive fit a LT77 with a 200TDI? Quote Link to comment Share on other sites More sharing options...
western Posted April 17, 2009 Share Posted April 17, 2009 Fits on the Transfer box to the left of the transmission brake drum, so it should fit all 90/110 vehicles regardless of what engine is fitted. Quote Link to comment Share on other sites More sharing options...
JST Posted April 17, 2009 Share Posted April 17, 2009 sounds a good price i would go for it. if you do alot of heavy towing then dont change to 1.22 ratio T box. my td5 pulled 3T with OD engaged quite happily many a time but i liked the 1.4box for pulling away and up through the gears over a 1.2 when towing Quote Link to comment Share on other sites More sharing options...
