fats_40 Posted September 26, 2008 Share Posted September 26, 2008 have p38 which is hesetant on pulling away,its fine at speed.done the usual plugs and leads but problem still there.some times it wants to stall so you blip the throttle and its fine any ideas people.thanks Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted September 27, 2008 Share Posted September 27, 2008 My initial guess is the MAF needs cleaning or replacing. However, other people have more experience with the V8 38A than I do. It might help them if you say what year your car is, and what size the engine is, as there are two different Engine Management systems. People will tend to assume an automatic gearbox. HTH, one way or the other. Quote Link to comment Share on other sites More sharing options...
Escape Posted October 1, 2008 Share Posted October 1, 2008 On older cars, the adaptive values of the ECU (GEMS) can drift a bit over the years. I had similar problems after the rebuild, and solved it by resetting the adaptive values. Really made a big differene, in mpg as well, as she was running way too rich on low rpms. Quote Link to comment Share on other sites More sharing options...
