kevinr Posted September 29, 2008 Share Posted September 29, 2008 When I'm accelerating through 1st and second gear, the car starts to misfire. I've checked all I can on it, but everything seems in check..no vaccum leaks, sparks and HT leads are new, dizzy cap and rotor arm are clean as a whistle..I cant see any oil leaks (well, not of the usual disco variety). Any ideas what could be the next step? Is it possible to swap the coil out with a replacement to test it without going through the hassel of completely removing the old one and putting the new one in fully? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 29, 2008 Share Posted September 29, 2008 You can stick a spare coil in temporarily to test it. The ignition amplifiers do go faulty, especially when hot. Failing that, run through the EFI diagnostics guide in the tech archive. Quote Link to comment Share on other sites More sharing options...
kevinr Posted September 29, 2008 Author Share Posted September 29, 2008 thanks fridge..The amp is only 3 months old, after it popped on me last time..I seriously hope it's not the culprit now..not at £30 a go!..lol Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 29, 2008 Share Posted September 29, 2008 You could always try the GM upgrade. Quote Link to comment Share on other sites More sharing options...
kevinr Posted September 29, 2008 Author Share Posted September 29, 2008 You could always try the GM upgrade. I had a look at that...very intruiging but trying to source that replacement amp is proving hard, the motorfactors round here can't seem to cross frerence that part no to anything. As to the misfire, with the exhaust system popping along merrily to the misfire, I decided to play with the air-flow meter, I removed the cable...accelerated hard..and no jumping ..so I replaced the cable...accelerated hard..and still no jumping..it's as if the problem didn't exist. So could this issue be related to the airflow meter..maybe getting dirty connections from my recent bout of greenlaning, or could this just be fluke?..it just seems odd that the problem would go away like that..just as suddeny as it appeared Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 29, 2008 Share Posted September 29, 2008 Yes it could be the AFM I suppose, if it is saying there is more or less air going in than there actually is then the mixture would be up **** creek - disconnecting the AFM probably makes the ECU use a default set of airflow values based on rpm I would think. Quote Link to comment Share on other sites More sharing options...
