Rocket Posted January 26, 2006 Share Posted January 26, 2006 Hi Guys Which autobox and Transfer box would be fitted to an 88 F reg 3.5 V8 Range Rover? Would the disc rear axle fit my 1989 V8 Ninety? Cheers Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 26, 2006 Share Posted January 26, 2006 ZF 4 Speed with a LT230 Yep axle will fit, check that both shocks face forwards on both your 90 and RR which they should at these years, its a nuts bolts and PITA job but worth it HTH Nige Quote Link to comment Share on other sites More sharing options...
Rocket Posted January 27, 2006 Author Share Posted January 27, 2006 ZF 4 Speed with a LT230Yep axle will fit, check that both shocks face forwards on both your 90 and RR which they should at these years, its a nuts bolts and PITA job but worth it HTH Nige Hi Nige How did I guess it would be you that answered! Good news on the Axle. My shocks definitely face forward but I'll have to check the RR. Re the LT230 would that by any remote chance be a 1.192:1 ratio? and would you happen to know if the RR half shafts, diffs and CVs would be interchangeable with those of my 1989 V8 Ninety? Cheers Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 27, 2006 Share Posted January 27, 2006 The transfer box in the RR should be a 1.222:1 ratio Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 27, 2006 Share Posted January 27, 2006 Rear Half shafts no, Rear diff yes, Front CVs no, front shafts no front diif yes front casing Yes Rear Casing no Nige Quote Link to comment Share on other sites More sharing options...
Rocket Posted January 27, 2006 Author Share Posted January 27, 2006 Rear Half shafts no, Rear diff yes, Front CVs no, front shafts no front diif yes front casing Yes Rear Casing no Nige Oh! I guess I can see why the rear half shafts are different because they probably have fixed drive plate on the wheel end but do they have the same number of splines at the diff end? and if so won't my shafts fit? Whats different about the rear casing? On the front of 90 I think I have a dodgy spline on the front nearside between CV and halfshaft. So wouldn't I be able to swap mine fore the RR? Cheers Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 27, 2006 Share Posted January 27, 2006 Oh!I guess I can see why the rear half shafts are different because they probably have fixed drive plate on the wheel end but do they have the same number of splines at the diff end? and if so won't my shafts fit? Whats different about the rear casing? On the front of 90 I think I have a dodgy spline on the front nearside between CV and halfshaft. So wouldn't I be able to swap mine fore the RR? Cheers Ha;f shafts on drummed axles are differnt to disc, they have the same slpines into the diff tho at this age - 10 spline Casing is completely different at the wheel ends, and they are not interchangeable as a casing with a disc saxle casing RR axklesd and 90 axles are completely different inside, CV on RR are seperate to the stub shafts, 90 have a one piece CV with stub shaft, the CV on the diff side have a selection of sizes, 1988 probably the weakest at 32 spline, and won't fit into 90 cv, but the diffs are 10 spline so will fit the 90 It wouild be very clear if you pulled the 2 front axles apart ! Nige Quote Link to comment Share on other sites More sharing options...
Rocket Posted January 27, 2006 Author Share Posted January 27, 2006 Ha;f shafts on drummed axles are differnt to disc, they have the same slpines into the diff tho at this age - 10 splineCasing is completely different at the wheel ends, and they are not interchangeable as a casing with a disc saxle casing RR axklesd and 90 axles are completely different inside, CV on RR are seperate to the stub shafts, 90 have a one piece CV with stub shaft, the CV on the diff side have a selection of sizes, 1988 probably the weakest at 32 spline, and won't fit into 90 cv, but the diffs are 10 spline so will fit the 90 It wouild be very clear if you pulled the 2 front axles apart ! Nige Thanks Nige So when HD half shafts are mentioned for V8s this only refers to different splines on the wheel/CV end? so are all diffs regardless of engine or year 10 spline (I'm only talking about coilers here!)? Cheers Quote Link to comment Share on other sites More sharing options...
