88inchthing Posted November 15, 2008 Share Posted November 15, 2008 Hi all Yesterday i had a look at a Disco TD5 for a family member.The engine cut out on him and now won't start.When it did run it was holding back.The fuel pump in the tank does no run either with ignition or when cranking.The fuel pump relay in the fuse box under the bonnet is pulling in.I have checked all the relavent fuses and all are ok.I have also tried to read the fault codes, but for some reason the vehicle will not comunicate at all( i am using a bosh KTS machine). I will spend some more time on it later, but if anyone has any ideas they are most welcome. Many Thanks Bill Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 15, 2008 Share Posted November 15, 2008 The fuel pump and pump pressure are not registered by the ECU anyway. If your pump does not run and the fuse is ok, then the chances are the pump is FUBAR. Best take off the plate under the floor to see if there is power to the pump. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 15, 2008 Share Posted November 15, 2008 Pump is 'ked as Chris says Quote Link to comment Share on other sites More sharing options...
88inchthing Posted November 15, 2008 Author Share Posted November 15, 2008 Pump is 'ked as Chris says Thanks Guys I haven't looked at it again yet but he has already put a new lift pump on it.Please keep the ideas coming. Cheers Bill Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 17, 2008 Share Posted November 17, 2008 A TD5 doesn't have a lift pump. It just has a high-pressure 4 bar pump in the tank. Quote Link to comment Share on other sites More sharing options...
88inchthing Posted November 18, 2008 Author Share Posted November 18, 2008 A TD5 doesn't have a lift pump. It just has a high-pressure 4 bar pump in the tank. Hello again Now sorted thanks. Quote Link to comment Share on other sites More sharing options...
Skanny Posted November 19, 2008 Share Posted November 19, 2008 Hello againNow sorted thanks. So what was the problem? Quote Link to comment Share on other sites More sharing options...
