boneheaddread Posted November 15, 2008 Share Posted November 15, 2008 Hi , I have a 94 disco , in the last week , my charging light has started staying on when I turn off the car??? when I turn the ignition on instead of all four dash lights coming on the charge light stays off .??? the landy runs fine ,charges ok with no other problems , but then when I stop turn and off the ignition , bang on comes the charge light , I have pulled apart and cleaned all conectors battery terminals and leads on the altenator , now I have to disconect the battery every time I stop to aviod draining the battery , HELP Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 15, 2008 Share Posted November 15, 2008 The regulator on the alternator has gone, you can often buy them separately for about £15, or you can fit a new alternator. Quote Link to comment Share on other sites More sharing options...
boneheaddread Posted November 15, 2008 Author Share Posted November 15, 2008 The regulator on the alternator has gone, you can often buy them separately for about £15, or you can fit a new alternator. Hi ,thanks for the info , How does the alternater draw currant from the battery when the engine is turned off??? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 15, 2008 Share Posted November 15, 2008 Because part of the regulator unit is a diode pack which stops the current leaking through the alternator when the engine is off and if this doesn't work properly, current can flow in the wrong direction which flattens the battery. Not an uncommon problem. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 15, 2008 Share Posted November 15, 2008 Hi ,thanks for the info , How does the alternater draw currant from the battery when the engine is turned off??? Through the diodes in the regulator pack, if they go faulty. Quote Link to comment Share on other sites More sharing options...
