chrism Posted November 18, 2008 Share Posted November 18, 2008 Anyone know of somewhere i could get a model of an LS1, preferably a solidworks part or assembly file? I only need external dimensions really as i want to start designing a buggy around one. Im not sure which gearbox i want yet so i will probably cross that bridge when i get to it, unless some one has a complete engine/gbox/tbox drawing that looks suitable! Also a model of a front mog 404 axle would be nice but i can measure most of it from one of my axles Any help appreciated Chris Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted November 18, 2008 Share Posted November 18, 2008 Chris, it didn't exist when I was looking a couple of years ago. I asked on LS forums in the States, but it seemed these things were closely guarded. I ended up making a wireframe model (lifesize). The very basic dims are all over the net, enough for you to cobble together a rough physical model of the outline. Al. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 18, 2008 Share Posted November 18, 2008 or you can buy a resin block - has all the mounting holes in the right place so you can mock up to your hearts content and lift it in and out with one hand Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted November 18, 2008 Share Posted November 18, 2008 Yeah, but the price!!! Quote Link to comment Share on other sites More sharing options...
chrism Posted November 19, 2008 Author Share Posted November 19, 2008 I did a search and like you found an ls forum, didnt find much but like you say i think it will be a case of find as many pictures and basic dimensions as i can! Nobody know of any drawings of portals then? Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted November 19, 2008 Share Posted November 19, 2008 There is a diagram of the basic Mog axle dimensions floating abour, but its not specific enough to have portal box geometry. If you have the axles, just spend 3 mins with a tape measure??? Just how precise does a mock up need to be anyway - its mostly about the shaft centrelines and clearance of hubs / brakes etc for the wheel. Al. Quote Link to comment Share on other sites More sharing options...
steffUK Posted November 19, 2008 Share Posted November 19, 2008 You can always take your tape measure and go to your friendly Chevy dealer / Unimog dealer and spend some time there. There are also so many different Unimog axles around. Quote Link to comment Share on other sites More sharing options...
steve_d Posted November 19, 2008 Share Posted November 19, 2008 I'm told there is one on here http://sema.org/techtransfer/ But you would need to be a member to download it (2Gb) Next question....is anyone a member of Sema? Steve Just to really pi$$ you off it is an LS7 and includes every external part including the spark plugs. Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted November 19, 2008 Share Posted November 19, 2008 The LS7 has a different sump though. If it helps the engines are about an inch bigger in all directions than a small block Chevy Quote Link to comment Share on other sites More sharing options...
integerspin Posted November 23, 2008 Share Posted November 23, 2008 email an engine supplier. I would have thought someone would give at least external drawings. I mailed perkins for engine drawings and they sent them to me.. Quote Link to comment Share on other sites More sharing options...
Warthog Posted November 23, 2008 Share Posted November 23, 2008 or you can buy a resin block - has all the mounting holes in the right place so you can mock up to your hearts content and lift it in and out with one hand Stumbled upon this Ebay trader: http://cgi.ebay.co.uk/Engine-Replica-w-v-c...1742.m153.l1262 They seem to be able to order different models of Engine and Transmission? Quote Link to comment Share on other sites More sharing options...
