gsr341 Posted January 30, 2006 Share Posted January 30, 2006 hi im fitting gwyn lewis's challange suspension , in the coming weeks , but plan on changing the suspension bushes at the same time . does any kind sole know the lr part numbers (and correct names) for the following please front radius arm bushes (both axel and chassis side) rear trailing arms bushes , (chassis side only) 'A' frame to bracket bushes any any others you think may require a look at its a 1994 300tdi 90 by the way cheers Dafydd Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted January 30, 2006 Share Posted January 30, 2006 I'm no help with part numbers but I'd say the greatest angular displacement to be on the (rear A-frame or) the front panhard rod. While you've got the hacksaw and blowtorch out... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 30, 2006 Share Posted January 30, 2006 The 4 round radius arm to axle bushes: NTC6781 "Bush, front suspension radius arm" radius arm to chassis ones: NRC4514 "bush" panhard rod ones: ANR3410 "bush,panhard rod" trailing arm to axle: NTC1772 "bush-rear-lower arm rear suspension" triangle type trailing arm to chassis: NTC9027 "mounting-lower link flexible rubber" A frame ball joint: ANR1799 "joint-rear suspension upper link ball" A frame arms to chassis: NTC1773 "bush,rear suspension upper link" HTH. Jamie Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2006 Share Posted January 30, 2006 front radius arm bushes --axle end--To (V) KA 930455--ntc7307 or from (V) LA 930456--ntc6781 ------------------------------chassis end--To (V) VA 130784--nrc4514 or From (V) VA 130785--anr6971 rear trailing arms bushes , (chassis side only) to (V) JA 910736--stc618 or From (V) JA 910737--ntc9027 'A' frame to bracket bushes ntc1773 hope that helps Quote Link to comment Share on other sites More sharing options...
gsr341 Posted January 30, 2006 Author Share Posted January 30, 2006 cheers guys Quote Link to comment Share on other sites More sharing options...
