Bumpyride Posted November 27, 2008 Share Posted November 27, 2008 gents 200tdi 110 as the exhaust comes down from the engine block about 300 mm in the vertical direction there is a bracket (welded) on the down pipe, which appears to be at the same level at a tapped boss on the engine block - i presume these are suppose to attach to each other to reduce the vibration in the downpipe. Only problem is that it appears to require an intermediate bracket to joint the exhaust bracket and the boss on the engine - is this true? Also anybodt have any idea of the thread on the engine block? anybody has a copy of the parts for this section and illustration it would be much appreciated - or a phot for that matter. sorry if this is a bit hard to understand] many thanks Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 27, 2008 Share Posted November 27, 2008 Yer go..... Part # 3, "bracket", is ESR266, £8.73 #6, "bolt, hexagon socket M8x16" SS108161L £1.30 #4, "screw, hexagon M6" SS108161L 36p #8 , "screw,hexagon M10" SH110141L 36p #7, washer, 8mm WA108056 13p #5 washer 6mm WJ106001L 36p #9 washer 10mm WA110061L 36p Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 27, 2008 Share Posted November 27, 2008 I suppose I should fit 1 to my truck as well . Exhaust seems to slip at the top. So I would hope that the bracket would cure that Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 27, 2008 Share Posted November 27, 2008 Yeah, it does help Mark. on my 200 I used to have, the bracket bit cracked through and the pipe kept slipping down off the turbo flange. (and getting those small allen head bolts in was a royal PITA. I cut down an allen key in the end so it was only about 10~12mm deep, and that worked a treat, just took ages to wind the screw in though.) Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 27, 2008 Author Share Posted November 27, 2008 thanks very much lads perfect A* Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 27, 2008 Share Posted November 27, 2008 Hmm, maybe that's why the dowpipe seems to be slipping off on mine....there's quite a worrying gap between the turbo and the top of the downpipe Need to look into this bracket stuff methinks Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2008 Share Posted November 27, 2008 haven't got that extended bracket on my 200Tdi, just the downpipe bolted direct to the block. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 27, 2008 Share Posted November 27, 2008 On mine the gap between the exhaust and the block is about an inch or so. Will be ordering the bracket in the week Quote Link to comment Share on other sites More sharing options...
