Badger90 Posted November 29, 2008 Share Posted November 29, 2008 Hi chaps..i'm need of some advice... i have a LT77 gearbox on my defender, at the moment have no transfer box on and i have drained the extension housing oil out.. and have no idea what oil, have a little idea how to put it back in.. isnt there a grub screw undert he main shaft to poor oil in? and anyone know what oil it takes?im thinking EP90?cheers thensam Quote Link to comment Share on other sites More sharing options...
fender1234 Posted November 29, 2008 Share Posted November 29, 2008 it takes ATF or if you have a seach there are other types of oil recomended. there is a little square plug on the side of the box 13mm spanner to undo it. hope this helps Quote Link to comment Share on other sites More sharing options...
Badger90 Posted November 29, 2008 Author Share Posted November 29, 2008 do you roughly know which side and how far it ment to be up the casing.. i just looked and all i found was a bango fitting with a pipe about half way up and a earth wire?cheers Quote Link to comment Share on other sites More sharing options...
western Posted November 29, 2008 Share Posted November 29, 2008 LT77 oil needs to be ATF or MTF94 7 the Transfer box LT230 has EP90, main gearbox fill/level is on the righthand side of the casing directly above the area where the serial number is stamped, the transfer box fill/level is on the rear face just to the left of the transmission brake drum. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted November 29, 2008 Author Share Posted November 29, 2008 ohhh soo when you fill the gearbox up it allso fills the extension housing up? i was looking for a seperate plug for the extension house... is that right? Quote Link to comment Share on other sites More sharing options...
western Posted November 29, 2008 Share Posted November 29, 2008 Yes the extension housing is part of the main gearbox & uses the same oil. the rearmost casing that the front & rear propshafts connect to is the transferbox & is filled as explianed above. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted November 29, 2008 Author Share Posted November 29, 2008 Yes the extension housing is part of the main gearbox & uses the same oil. the rearmost casing that the front & rear propshafts connect to is the transferbox & is filled as explianed above. ok thanks for that Quote Link to comment Share on other sites More sharing options...
