change transfer ratio
yup, you'll need to drop the t-box. have been there done that.
there are 2 gears that you need to change.
This is what the kit looks like.
http://www.facebook.com/photos.php?id=6939...mp;id=693928001
it will help if you have the LT230q/t overhaul manual, you will know exactly which gear is being replace. it looks easy, but playing lego with the gears is no fun when you need to get it back into running conditions. pick someone who really knows the LT230 or else, it could end up leaking lots after.
