pritch1 Posted February 3, 2006 Share Posted February 3, 2006 Well my landys loosing huge amounts of oil again and this time it appears to be the front oil seal on the transfeer box. ( the output for the front prop ). so ive gone underneath and it seems that the bearing is worn as well with up and down movement. I have had alook in the manual to no avail is this going to be a new box or can i change the bearing and oil seal easily? Quote Link to comment Share on other sites More sharing options...
white90 Posted February 3, 2006 Share Posted February 3, 2006 Well my landys loosing huge amounts of oil again and this time it appears to be the front oil seal on the transfeer box. ( the output for the front prop ). so ive gone underneath and it seems that the bearing is worn as well with up and down movement. I have had alook in the manual to no avail is this going to be a new box or can i change the bearing and oil seal easily? How much up and down movement? more than 3-5mm? the front bearing is a rollerball type there is an amount of movement that is perfectly ok far more likley is a worn flange that has wrecked the seal a new flange is only £15-20 plus a genuine seal for £3-4 and the jobs is done. I'll wager a £5 the bearing is fine ps if I'm wrong you can change it insitu not easy but possible. Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 3, 2006 Author Share Posted February 3, 2006 looks like i owe you that 5er it is only about 5 mm of play so should be ok, ill just replace the seal and flange just got to track down the annoying wine at over 50 mph now driving me crazy. Quote Link to comment Share on other sites More sharing options...
JST Posted February 3, 2006 Share Posted February 3, 2006 'got to track down the annoying wine at over 50 mph now driving me crazy.' No oil in the T box or tell the misses to stop talking! Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 3, 2006 Author Share Posted February 3, 2006 well there is oil in transfeer box, so gotta be the mrs, hmm how to keep her quiet Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 3, 2006 Share Posted February 3, 2006 Fill her up with EP90 too that should cut the noise down for a while Quote Link to comment Share on other sites More sharing options...
