nwfr1 Posted December 29, 2008 Share Posted December 29, 2008 Hello chaps. Have a 24v REME recon 2.25 which I am going to change to 12v and put in my series 1. Can anyone tell me what would be the correct spak plugs and the compression ratio as paperworkless aprt from a power check chart. Many thanks. Quote Link to comment Share on other sites More sharing options...
101sean Posted December 30, 2008 Share Posted December 30, 2008 Should be standard 8:1 compression so bin any 24V bits and fit standard 12V stuff inc reccomended 2.25 non screened plugs. Quote Link to comment Share on other sites More sharing options...
Monster Posted December 30, 2008 Share Posted December 30, 2008 Hello chaps. Have a 24v REME recon 2.25 which I am going to change to 12v and put in my series 1. Can anyone tell me what would be the correct spak plugs and the compression ratio as paperworkless aprt from a power check chart. Many thanks. Not what you asked but... You can use the screened system as a temporary measure until you get the correct bits. I believe there is a dropper resistor before the coil to allow it to be used on a 24v system. The distributor doesnt have the nice vacuum advance like the civilian type though. Cheers. Quote Link to comment Share on other sites More sharing options...
