V8 90 JON Posted January 10, 2009 Share Posted January 10, 2009 my rear hub is dead bearing collapsed and damaged the seat for the oil seal...i've got a front hub which looks almost identical the only difference i can see is a 4mm difference in the wheel face to the front face ...any ideas if it will fit ok ?? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 10, 2009 Share Posted January 10, 2009 As with all things LR there are a selection of hubs and stub shafts, Whilst all hubs are interchangable, front to back only if they are the same front and back and the same as what you have that your changing if to and for If that makes sense ? Nige Quote Link to comment Share on other sites More sharing options...
V8 90 JON Posted January 10, 2009 Author Share Posted January 10, 2009 As with all things LR there are a selection of hubs and stub shafts,Whilst all hubs are interchangable, front to back only if they are the same front and back and the same as what you have that your changing if to and for If that makes sense ? Nige yes kind of!! the size difference is only 4mm this will efectivly only move the half shaft 4mm further into the diff as long as the shaft dosen't botomout into the diff i can't see this being a prob ?your thoughts.. hows the hard top truck cab conversion going ?i'm assuming you also have sub zero temps..its -3 on my drive!! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 10, 2009 Share Posted January 10, 2009 yes kind of!! the size difference is only 4mm this will efectivly only move the half shaft 4mm further into the diff as long as the shaft dosen't botomout into the diff i can't see this being a prob ?your thoughts.. hows the hard top truck cab conversion going ?i'm assuming you also have sub zero temps..its -3 on my drive!! Cold - er yeah could say - a Spanner stuck to my skin today Hardtop off - T Cab is on Cage welding and write up tomorrow Its not JUST the hubs its the stub axles that it goes on are differing widths and lengths, .....often known as Narrow bearing hubs etc What eaxctly is the Model / year / 4x4 axle you have an issue with off, ...........I have a selection Nige Quote Link to comment Share on other sites More sharing options...
V8 90 JON Posted January 10, 2009 Author Share Posted January 10, 2009 yes kind of!! the size difference is only 4mm this will efectivly only move the half shaft 4mm further into the diff as long as the shaft dosen't botomout into the diff i can't see this being a prob ?your thoughts.. hows the hard top truck cab conversion going ?i'm assuming you also have sub zero temps..its -3 on my drive!! its (i think ) a range rover clasic rear axle circa 1980 im going (soon) to replace the whole axle with a newer one, so a get it giong for now will do ! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 10, 2009 Share Posted January 10, 2009 its (i think ) a range rover clasic rear axle circa 1980 im going (soon) to replace the whole axle with a newer one, so a get it giong for now will do ! 1980 is early - thats a "Pre Efi" type Can you loom at the end of the studs, are they balnk, or do they have a "slot" or triangle stamped into them ? Nige Quote Link to comment Share on other sites More sharing options...
teslo Posted January 11, 2009 Share Posted January 11, 2009 Hi, how does halfshaft look like? Rear are from one piece? Front hub flanges are separate from shaft? Are you sure that those 4 mm are only difference( bolt holes for driving members are same)? Quote Link to comment Share on other sites More sharing options...
