tjolliffe Posted January 17, 2009 Share Posted January 17, 2009 Hi guys, Just a quick question, does anyone know where the axle number is printed on an early 90? Need to find it out in order to buy the right parts (seals ect.) from paddocks. Any help would be great! Cheers Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2009 Share Posted January 17, 2009 front axle left hand axle tube on the top face above the horizontal weld line, might need a bit of cleaning to read it, rear azle will be similar location but on the right tube as the axle casing main section is common. Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted January 17, 2009 Author Share Posted January 17, 2009 Thanks Western, big help, will go out and check it in a bit Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted January 17, 2009 Author Share Posted January 17, 2009 Ok, figured out it's FTC4785 that I need to use. Which way around to I fit the seal (havent got the old one for reference). Do i fit it petruding lip facing stub axle or facing the bearing? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2009 Share Posted January 17, 2009 the 2 seal lips should face the bearing. Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted January 17, 2009 Author Share Posted January 17, 2009 the 2 seal lips should face the bearing. Not sure quite which way around that is? First or Second photo facing the bearing? Sorry for my apparent stupidity! Cheers Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2009 Share Posted January 17, 2009 as per 1st photo, the single lip fits over the boss on the stub axle. Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted January 18, 2009 Author Share Posted January 18, 2009 Cheers, thanks very much! Quote Link to comment Share on other sites More sharing options...
