transfer box oil seal
My 110 has decided to carry out a bit of under body self lubrication, it spraying oil out of the hand brake leaving a lovely oil sheen underneath. From looking through previous threads I'm guessing its the transfer box oil seal so I'll change that. Is there anything else i should look at or change while I'm doing it, such as the bearing itself. I also noticed there is oil leaking from the transfer box cover plate. Is this just a case of new gasket or do i need to look elsewhere. All advice much appreciated. :)
Thanks for the numbers western, I'm just about to order the parts as i've got a few days off this month. I'm thinking of getting a new bearing just in case but am struggleing to find the right number for it, any help much appreciated (chassis No EA323114). Changing the front prop shaft UJ's aswell should i replace the nuts when doing this.
