western Posted February 1, 2009 Share Posted February 1, 2009 Husky's are excellent winch's, I've got one on my 110 & a 2nd to go on my rally recovery trailer eventually. get some 85/140 gearoil & do a oil change on it before use, there's 2 allen socket plugs one on the front of the gearbox casing & the 2nd under the cable drum, fill from the front plug & drain from the 2nd plug, you'll need aroud .6 of a litre. Quote Link to comment Share on other sites More sharing options...
ste clark Posted February 1, 2009 Author Share Posted February 1, 2009 Husky's are excellent winch's, I've got one on my 110 & a 2nd to go on my rally recovery trailer eventually. get some 85/140 gearoil & do a oil change on it before use, there's 2 allen socket plugs one on the front of the gearbox casing & the 2nd under the cable drum, fill from the front plug & drain from the 2nd plug, you'll need aroud .6 of a litre. just noticed that when i release the handbrake/freewheel lever thingy a liittle bit of gearoil comes up through the bottom of it... is this normal or do i need some seals too?? what are the oil change intervals and do they need any other servicing?? very grateful for all your help cheers ste. Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2009 Share Posted February 2, 2009 no oil should come from the free spool lever, sounds like a seal has given up, oil change periods are upto you but the manual says 'after 50 hours of winching or Annually, the spur gearbox [the bulge on the back the motor fits in to for drive] is BP Energrease FGL. & Don't use EP oils [i.e. EP90] it not good for the phosphor bronze bearings. hth Quote Link to comment Share on other sites More sharing options...
white90 Posted February 2, 2009 Share Posted February 2, 2009 The gearbox breather vents at the top of the freespool lever if the winch has been turned on its end or upside down then it may be residule oil in the vent leaking. Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2009 Share Posted February 2, 2009 The gearbox breather vents at the top of the freespool leverif the winch has been turned on its end or upside down then it may be residule oil in the vent leaking. Cheers Tony, I didn't know that, least I've learnt something today Quote Link to comment Share on other sites More sharing options...
