FridgeFreezer Posted January 31, 2009 Share Posted January 31, 2009 I'm pretty sure the current clutch kit fitted to the 109 (4.6 V8, 3.5 flywheel, R380 box) is a standard LT77 V8 kit, and I've found out the hard way that a P38 4.6 kit is not the same thing Now Paddocks website is adding to my confusion by listing several clutch kits: FTC4828 is the 3.9 92-94 version (I presume the R380 box was fitted from 92?) They then list bits separately so you have: FTC813 / FTC814 for the 3.9 V8 up to 92 576476 / FTC3197 for the 3.5 all models 86-94 ...and the release bearing is the same thing forever. This doesn't make things much clearer either Can anyone shed a bit of light on this mess, I thought V8 clutches were much of a muchness across the board Quote Link to comment Share on other sites More sharing options...
paintman Posted February 1, 2009 Share Posted February 1, 2009 You might find this of more use. Gives the clutch plate sizes as well. http://www2.qha.com/catalogues/QH08.pdf Par for the course. Tried the catalogue before posting the link & now its playing up - the rest of the QH catalogues are downloading fine. So if you are having a problem you might want to try later Quote Link to comment Share on other sites More sharing options...
paintman Posted February 2, 2009 Share Posted February 2, 2009 Tried the link again this morning. Still doesn't want to play in Mozilla Firefox, but works fine on AOL. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 2, 2009 Author Share Posted February 2, 2009 Works fine here, ta. Now I know what's fitted to what I'm even more confused about what to buy Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 27, 2009 Author Share Posted February 27, 2009 Conversing today with rakeway about their uprated clutch release bearings (of which I have one but needed a new bearing bit for) it turns out the longer-than-standard (EG longer than an FTC5200) version I have appears to have been sent entirely by accident rather than being an R380-specific one as I had assumed. They are sending me a "normal" length one to put in with the new clutch. I think it's just the sleeve on the back end that's longer and there appears to be plenty of room for that to disappear in the V8 bellhousing. Quote Link to comment Share on other sites More sharing options...
