gsr341 Posted February 14, 2006 Share Posted February 14, 2006 hi i bought sum sumo bars off QT servises @ donnington on sunday the arm behind the axel is no problem , but the sterring arm in the front, is slightly different the n/s is straight forward , but what is the correct way for the o/s ? the steering damper bracket is attached to the drop arm ball joint , so i must keep this , is the end of this threaded ? as per other side (ball joint end) also is the ball joint in the drop arm a serviceible item ie can it be removed .. any help gratefully accepted many thanks Dafydd Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 14, 2006 Share Posted February 14, 2006 the steering damper bracket is attached to the drop arm ball joint , so i must keep this , is the end of this threaded ? as per other side (ball joint end) Yes, and it is a left hand thread. also is the ball joint in the drop arm a serviceible item ie can it be removed .. Yes, there's a circlip on the bottom that allows it to be removed/replaced. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 14, 2006 Share Posted February 14, 2006 Yes, there's a circlip on the bottom that allows it to be removed/replaced. On some IIRC, others do not have a replaceable ball joint and you have to change the whole arm. Chris Quote Link to comment Share on other sites More sharing options...
gsr341 Posted February 14, 2006 Author Share Posted February 14, 2006 cheers boys , yep mine does have a circlip , am i right in assuming i may need the help of a press to shift the little blighter ? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 14, 2006 Share Posted February 14, 2006 You can get away without a press but it is best done off the car. Chris Quote Link to comment Share on other sites More sharing options...
