Fish13 Posted February 9, 2009 Share Posted February 9, 2009 Gents, When I indicate right, the light on the dash flashes on and off as it should. When I indicate left, the light on the dash doesn't flash? I guess it's a problem with the switch, but what am I looking for here? Dirty contact, snapped wire or what? Not electrickery minded, so need some background info before I start pulling things apart! Many thanks, Fish. Quote Link to comment Share on other sites More sharing options...
Dengie Boy Posted February 9, 2009 Share Posted February 9, 2009 First check the indicator bulbs front and rear. Then check the wiring plugs located behind the light units. Unplug, clean connections and retry. This will sort out 99% of lecky problems If no joy, then use a multimeter on the light connections to see where you have the power. Goodluck Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 10, 2009 Share Posted February 10, 2009 Do the left indicators work? Does the left dash light work when you operate the hazard switch? If your answers are "yes" and "no" respectively then I would go straight for the bulb. Quote Link to comment Share on other sites More sharing options...
Fish13 Posted February 13, 2009 Author Share Posted February 13, 2009 Thanks Gents, Turned out it was a loose connection from the indicator on the wing. Pushed it back in and the bulb on the dash started again! Cheers, Fish. Quote Link to comment Share on other sites More sharing options...
