graemejudge Posted February 10, 2009 Share Posted February 10, 2009 hi i seam to have aloud knocking noise coming from the rear of my 98 freelander it happens when turing shap corners and even turing at juctions i have noticed it has also stated happing when accerlating and slowing now any idears please quick responces would be helpful so i know if it going to cause more damage thanks Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2009 Share Posted February 10, 2009 I'd suggest the IRD unit is causing the problem Quote Link to comment Share on other sites More sharing options...
graemejudge Posted February 10, 2009 Author Share Posted February 10, 2009 I'd suggest the IRD unit is causing the problem thanks but isn't ird at front the knocking noise sounds like something is hitting to floorpan near rear seats Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2009 Share Posted February 10, 2009 http://www.ashcroft-transmissions.co.uk/category_8.html More info in the link ^^^^ Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 10, 2009 Share Posted February 10, 2009 Early Freelanders have weak diffs, which are/were prone to bearing failure. Check for leaks, play where the drive shafts exit the diff, the drive flange on the diff nose, and the the mounting on the drivers side of the diff nose. Freelander diff pinion nose bearing - The front mounting - Les. Quote Link to comment Share on other sites More sharing options...
