mudmuncher Posted February 17, 2009 Share Posted February 17, 2009 Hi Just got a new rear prop for my series 3 and have a couple of questions . I have a gaiter for the sliding joint in the shed, should i fit it or not ?? (i dont really want to take the prop apart but if they are best fitted i will ) Would youy need to greese the uj/sliders or do they come pre packed ?? Cheers chris Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted February 17, 2009 Author Share Posted February 17, 2009 Anyone help ? Quote Link to comment Share on other sites More sharing options...
stuntman Posted February 17, 2009 Share Posted February 17, 2009 Hello MM, most seem to perish and fall off eventully and don't seem to do much damage, although you 'should' probably fit it, the UJ should come with a small amount of grease however if like the defender ones, you will need to top this up. Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 17, 2009 Share Posted February 17, 2009 Throw the rubber boot away. Horrible hateful things. They only fill up with mud and mud and grease mixed together form an excellent grinding paste. Just keep greasing it regularly. Yes you should grease new U/j's when fitting. Jon Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted February 17, 2009 Author Share Posted February 17, 2009 Cheers for that i will throw it away Thanks John Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted February 17, 2009 Author Share Posted February 17, 2009 Cheers Stuntman Many thanks for the advice Cheers chris Quote Link to comment Share on other sites More sharing options...
Cartman Posted February 20, 2009 Share Posted February 20, 2009 I have always fitted a gaiter over the splines and not ripped one yet. Can't be trying hard enough? Quote Link to comment Share on other sites More sharing options...
