The Badger Posted February 18, 2009 Share Posted February 18, 2009 I have the shorter drop arm, one found on a disco, this does not use the Ball Joint at the end and is slightly shorter. Does anyone know where I might find destruction's to work out how it connect to the adjustable pan head rod I have? Im still learning... Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 18, 2009 Share Posted February 18, 2009 all you should need is the drag link end for the rh side of the rod Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 18, 2009 Author Share Posted February 18, 2009 ok, should have one of those, do you have a of the set up? Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 18, 2009 Author Share Posted February 18, 2009 photo? pretty sure my drop arm is different as there is no space for the ball joint? It looks like the Ball joint bolt comes down into the hole? As opposed from the ball joint being inside the Drop arm? Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 18, 2009 Share Posted February 18, 2009 The drag link has a track rod end in it and, as you say, the track rod end goes up through the arm with the nut on the top of the arm. The drag link is longer than a standard Defender one. Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 18, 2009 Share Posted February 18, 2009 the ball joint goes up from underneath the drop arm, nut on top of arm. no pics sorry, only going from when we converted a defender to a disco drop arm. Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 18, 2009 Author Share Posted February 18, 2009 Great, two answers and they are both the same... Great, nice one, I see why the guys who supplied the box said this is better than the old style version. Where does the steering damper connect to then? Sorry more questions, as im now unsure where the steering damper connects? On the older versions you had that little link that connected to the drop arm / drag link and steering damper, where does the damper connect to now? thanks for the info. Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 18, 2009 Share Posted February 18, 2009 Better late than never... You have a few options on the damper. 1) Don't bother with one, you don't need one anyway as they're only there to disguise problems elsewhere. 2) Get a clamp on bracket that goes onto the drag link. 3) mount one on the tracking bar behind the axle as per Discovery. I have chosen option 1 for since around 1993 and never had a problem. Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 18, 2009 Author Share Posted February 18, 2009 Ah, great, much appreciated as a picture is mush easier for dullars like myself... Quote Link to comment Share on other sites More sharing options...
The Badger Posted February 18, 2009 Author Share Posted February 18, 2009 How's that twin shock set up like on the front? Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 18, 2009 Share Posted February 18, 2009 How's that twin shock set up like on the front? This might give you an idea how it works... If you're using relatively cheap and cheerful shock absorbers like me they make a huge difference reducing understeer dramatically and getting rid of the "dive" when you hit a hole/bump at speed. The rears are also double up to reduce the kangaroo effect you otherwise get on washboard sections. Quote Link to comment Share on other sites More sharing options...
