moony123 Posted March 17, 2009 Share Posted March 17, 2009 hey all i need to find out how i can run a return fuel line from the original series tank to the 200tdi/disco fuel filter?????? does it need 1 i have most bits well everything off disco so can i do it without buying anything cheers everyone any help very greatful luke Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted March 17, 2009 Share Posted March 17, 2009 Was your series a diesel to start with,or a petrol? Quote Link to comment Share on other sites More sharing options...
moony123 Posted March 17, 2009 Author Share Posted March 17, 2009 [a diesel then to a v8 now ive put a 200tdi Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted March 17, 2009 Share Posted March 17, 2009 the diesels should have a return on the top of the tank,towards the front edge. Run a pipe from the tank to the bulkhead.......should be easy....as long as nobody has taken the return off the tank Quote Link to comment Share on other sites More sharing options...
moony123 Posted March 17, 2009 Author Share Posted March 17, 2009 i will give it a go tomorrow and will let you know cheers for your advice mate Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 18, 2009 Share Posted March 18, 2009 Run the return line to the fuel filter housing if you have spare connections on it. Les. Quote Link to comment Share on other sites More sharing options...
moony123 Posted March 18, 2009 Author Share Posted March 18, 2009 hows it going just had a look at the tank in the centre obviously the sender unit,then 1 pipe on the top seems to be the only pipe there. following along to what seems to be an electric fuel pump(do i need this)then a pipe from that to the engine. what i did notice was like a very small plate on the top of the tank with 2 screws could this be where the return line used to be Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted March 18, 2009 Share Posted March 18, 2009 The elec pump was prob put in for the v8 so bin it as it will just be a restriction now. Yes,the plate with two screws is where a factory 2.25D return would go,but as Les said if there is a spare inlet on the filter housing(i belive there is),then just plumb to that Quote Link to comment Share on other sites More sharing options...
Feltham Posted March 21, 2009 Share Posted March 21, 2009 Agree with Les, Best to run rtn straight back to fuel filter. Personally I'd also use a one way valve, see through pipe and an air bleed just to be on the safe side Quote Link to comment Share on other sites More sharing options...
