V8 90 JON Posted March 19, 2009 Share Posted March 19, 2009 Hi my 54 plate diesel L322 wont start, turns over ok lots of fuel in the tank, checked all the fuses relating to alarm and fuel pump but it wont go!!! any one had similar experiance? Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 20, 2009 Share Posted March 20, 2009 Checked the inertia switch? Otherwise can you smell diesel? Could be you've got an air leak somewhere in the fuel lines. Jon Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted March 20, 2009 Share Posted March 20, 2009 Quite common for a TD6 - all the same reasons as a TD4 not starting. Low pressure electric pumps failing.(There are 2) Excess leakby in one or more fuel injectors. Failed fuel pressure regulator. Poor connections at fuel pressure regulator. A quick session on Testbook is usually the first port of call as the fault codes are accurate and you can tell alot from live data even with the engine stopped. Quote Link to comment Share on other sites More sharing options...
V8 90 JON Posted March 21, 2009 Author Share Posted March 21, 2009 it was indeed the low pressure pump (located behind a rectamgular palnel in the plastic under shroud just forward and inboard of the rear nearside wheel, a tap with a hammer got it going again and then a replacement from europarts ...£150 inc as apposed to landrovers £360 +vat!! Quote Link to comment Share on other sites More sharing options...
