winch power supply probblem
ok i got a superwinch s9000 but its 24v not complaining i got it cheap but how best is it to hunk it up
my defender is 12v so my options are to put two battery mounted in the back (moving the main battery from the front) then connecting the winch up to the two and then have a switch connected to a series link between the battery which mean i can flick a switch and make the circite 24v but this may blow my other electrics
next option is to mount 2 batterys in the back but this time keeping the main battery in the battery box so three in total and have a set of switches to disconect the front battery form the two in the back and as above to turn on the series connection a bit complicated but means the hole thing is controled by switches
third option is to use crocdile clips and a switch set up 3 bty as above switch to disconect front btyto rear and then have a series connection on croc clips to put on when i need to use the winch and then have a pump lead type set up to power the winch
or is there an easyer way
any help much needed
cheers shane
AS above fit a 12v motor
or if you do want 24v then fit two batteries in series and fit a 24v alternator. Then wire new batteries up to 24v alternator, keeping your 24v winch circuit totally isolated from 12v vehicle circuit.
this is the simplest and most effective way to power 24v winches.
Cheers
Steve
Cheers
Steve
how easy is it to fit a secound alternator ?? to a 3.5 rr engine
