Paul H Posted March 31, 2009 Share Posted March 31, 2009 Has anybody gone down the route of fitting a 300Tdi disco engine into a 90. I have a scrap RR classic with a 300 disco engine mated to a LT77 gearbox. The main problem that i can see will be the turbo/exhaust outlet position being at the bottom of the manifold directly above the chassis rail. The only other problems are likely to be the same as for a 200 Tdi conversion. If i am able to sort it i will be taking photo's and posting a build diary so watch this space. Quote Link to comment Share on other sites More sharing options...
bango690 Posted March 31, 2009 Share Posted March 31, 2009 the disco 300 exhaust misses the chassis rail on mine (disco auto running gear in a 90) Quote Link to comment Share on other sites More sharing options...
inchman Posted March 31, 2009 Share Posted March 31, 2009 sorry for high jackin your thread, bango 690 had you many problems fitting the autobox ? cheers Gary Quote Link to comment Share on other sites More sharing options...
Paul H Posted April 1, 2009 Author Share Posted April 1, 2009 Thanks for that Bango690. Did you use the 90 down pipe or the disco one? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted April 1, 2009 Share Posted April 1, 2009 I maybe wrong, but when thay went to the 300tdi there was very little diffrences between the disco, rrc and defender unlike the 200TDI, if using the R380 or auto box you'll have to move the engine mounts on the chassie(you may have to if putting it on the LT77). Quote Link to comment Share on other sites More sharing options...
Paul H Posted April 1, 2009 Author Share Posted April 1, 2009 Moving the engine mounts shouldn't be a problem if required. The existing TD engine is on an LT 77 and the incoming 300 is also on an LT 77 so hopefully that end of things should be straight forward. At least the mounts in the engine bay are accessable. Quote Link to comment Share on other sites More sharing options...
