Bluemoon Posted April 1, 2009 Share Posted April 1, 2009 I've got a Defender rev counter, ( in my Defender 300dti) being on about 2 years, but I've just upgraded my alternator from a Disco 300. now my revs show a lower reading. There's three terminals on the back of the rev counter earth, positive and input. Is it something I've just got to live with or is there a fix. cheers for any help Brian Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 1, 2009 Share Posted April 1, 2009 Compare the pullies on the two alternators, if they're different use the old pulley (if it'll fit!) Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2009 Share Posted April 1, 2009 if there's 3 small white slide switches on the back do this ---->>>> move the 3 slides so you get 1 & 3 up & 2 down, then refit & check the idle rpm it should read 750 to 800rpm & max rpm should be around 3850rpm. Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted April 1, 2009 Author Share Posted April 1, 2009 there are no switches, never thought about pulley been different, just thought there were all the same , will check tomorrow , cheers Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2009 Share Posted April 1, 2009 is it a genuine LR rev counter or one from another supplier ? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 1, 2009 Share Posted April 1, 2009 if there's 3 small white slide switches on the back do this ---->>>> move the 3 slides so you get 1 & 3 up & 2 down, then refit & check the idle rpm it should read 750 to 800rpm & max rpm should be around 3850rpm. Is that the back of the tacho or back of the alternator? Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2009 Share Posted April 1, 2009 on the rev counter as fitted to the V8 50th annivesary 90's [got one of these on my 200Tdi 110] Quote Link to comment Share on other sites More sharing options...
