ChrisJones117 Posted April 12, 2009 Share Posted April 12, 2009 86 '110' wiuth 200 TDi conversion Smalll concern reared its head yesterday after changing the bulb for gauge illumination, bulb blown so replaced it with nice shiny blue led conversion kit, had to take out gauge from pod to remove green plastic lens in gauge unit and after refitting it worked OK but later in day noticed that it was reading full when I knew that I only had 1/2 tank of fuel at best. Any ideas/suggestions, new gauge required or could it be the sender, does anyone know how to check gauge with multimeter. Any help appreciated Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 12, 2009 Share Posted April 12, 2009 You probably hooked it up wrong. The sender is around 280 Ohms empty and 15 fuel (the sender is 330 to 13 full range when out). Just measure resistance from the sender line to ground. Quote Link to comment Share on other sites More sharing options...
western Posted April 12, 2009 Share Posted April 12, 2009 might be the green lens jamming the needle, unlikely to be the wiring as the gauge/wire terminals are different types. Quote Link to comment Share on other sites More sharing options...
