jdixon7 Posted April 14, 2009 Share Posted April 14, 2009 Hi How do you remove / fit a rear side window on a RRC? Do you remove / fit the glass or the glass & rubber together? Thanks John Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted April 14, 2009 Share Posted April 14, 2009 You can take the window out with the runner still attached - if the runner is in decent nick I would imagine it is very difficult to fit the glass to it inside the door. Quote Link to comment Share on other sites More sharing options...
jdixon7 Posted April 15, 2009 Author Share Posted April 15, 2009 Hi Its the rear qtr glass not a door window. John Quote Link to comment Share on other sites More sharing options...
Orange Posted April 16, 2009 Share Posted April 16, 2009 It's a bit difficult to explain... Put the rubber around the glass, then put 2 lengths of strong string around the inside of the rubber (where it will fit over the panels), then with the aid of some lubrication around the inner edge of the rubber (I use washing up liquid) push the glass into the hole and pull the string to flip the inner lip over the panel. Then comes the hard part..... Fitting the filler strip (if it has one) is not the easiest of tasks, but it can be done without the proper tool. It will need to be well lubricated and will take quite a while with a thin bladed screwdriver or pallette knife. I have access to the proper tool, but the one I did at the weekend (90 truck-cab quarter light) was a right pain!! Hope that helps a bit... Quote Link to comment Share on other sites More sharing options...
