Disco 300tdi auto
nickm
Had a little search but couldnt find anything,
Basically my speedo is way out according to my satnav
any ideas what I can check/replace
according to my speedo top gear kicks in at 60mph satnav reads 48mph is this about right ?
80 on the speedo is around 65 on the satnav
Cheers
thats way out!
i checked mine with my sat nav and at 80 on the speedo, i was doing 75.
round a race track obviously.. ;)
can you rotate the center part of the speedo (needle part) if not, you could try putting a new dial in i spose?
CURLY
What size tyres are you running? and which transfer box?
If you do a search on speedo drive gears there are a number of gears available that can be swapped in and may give you a more correct reading.
Alternatly, your speed transducer may be knackered, but that is usually indicated by the occasional loss of any speedo reading at all, or erratic readings.
Mark
Hi
This is my completely standard road car
I did think about the transducer but also thought that that would be more complete loss of speedo
also thought about the gear where the speedo cable connects to the t box,
Can the gear be replaced easily ?
Hi
One or the other you don't have both, pre-March 1994 was cable.
My SatNav reads 70 but my speedo reads 75.
sorry forgot to say mines a 1997
would you know when top gear kicks in mines not til 60mph according to the speedo
cheers
