ben Posted April 27, 2009 Share Posted April 27, 2009 hi everyone just got some spot lights for the a bar on my td5 90 looking for any top tips for wiring them up as i'm not the biggest fan of messing about with electrics. and while i'm here i do a lot of motoway miles in the landy thinking off changing the gearing just wondered the best way of doing it cheers ben Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted April 27, 2009 Share Posted April 27, 2009 hi everyone just got some spot lights for the a bar on my td5 90 looking for any top tips for wiring them up as i'm not the biggest fan of messing about with electrics.and while i'm here i do a lot of motoway miles in the landy thinking off changing the gearing just wondered the best way of doing it cheers ben Presuming that you have aleady got 235/85/R16 tyres on with apropriate wheels then the best way is to alter the transfer box ratio from 1.410 to 1.222. The 1.410 is the standard ratio when in high so you low box will not be affected. The 1.222 was standard on the discoverys. Ashcroft transmissions do a kit or would probably do it for you. Otherwise rob the bits from a disco. Quote Link to comment Share on other sites More sharing options...
ben Posted April 27, 2009 Author Share Posted April 27, 2009 Presuming that you have aleady got 235/85/R16 tyres on with apropriate wheels then the best way is to alter the transfer box ratio from 1.410 to 1.222. The 1.410 is the standard ratio when in high so you low box will not be affected. The 1.222 was standard on the discoverys.Ashcroft transmissions do a kit or would probably do it for you. Otherwise rob the bits from a disco. cheers for that mate i have 265/75/16s on steel 8 spokes and does it mater what year the disco is Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2009 Share Posted April 27, 2009 in our Tech Archive index have a look in the Electrical section cos I'm sure there's a good diagram for extra light wiring. Quote Link to comment Share on other sites More sharing options...
