Probe on 300 TDi ?
Sabre
What is the function of the probe/monitor on top of the 300 TDi between the tappet cover and the inlet manifold ? Square terminal with 2 wires. Sits in the middle of the engine
Advice appreciated
Guest DiscoTD4
what year TDi please ?
If the ECU model then it's the coolant temp sensor used to determine injection advance and fuel quantity and 'talks' to the ECU. There is a separate temp sensor on stat housing used for the temp gauge.
Cheers
Cheers
Model is 1998 3-door, but fortunately not an ECU model, which means that we can discard the probe. The manifold gasket developed a leak, and fried the probe.
Thanks for all the advice, really appreciated
