bathtub Posted March 8, 2006 Share Posted March 8, 2006 Come on all you clever C**Ts . Brocken 3 boxes in 3 days at comps any alternatives over than drive carefully or gewt smaller tyres etc. snapping or twisting the main shaft. Fully hydraulic ,road legal????? Bigger box from lorry if so what 1 ??? Etc Etc Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 8, 2006 Share Posted March 8, 2006 Which ones have you got 3 4 6 8 bolt ? Strongest are the new Tempest Disco 2 types 3s are strong, 4 ok, 6s weak don't know re 8s. Think there are 2 types of 4 bolt std and HD ones, unsure what off tho Nige Quote Link to comment Share on other sites More sharing options...
will_warne Posted March 8, 2006 Share Posted March 8, 2006 Speak to Tomcat Motorsport, they do a quick ratio box with an HD sector shaft (you can't get a standard ratio HD box). You probably want to get the overassist option plus get the PAS pump flow rate increased (just some machining) to keep the steering nice and light. Its not a cheap option, though. I looked into it a few weeks ago but I didn't think I'f need it with my small tyres . IIRC its about £600 for the box and annother £100 or so for the pump. I think Adwest also do a quick ratio box but I'm not sure if the internals are beefed up. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted March 8, 2006 Share Posted March 8, 2006 £100 or so for the pump IIRC, somebody has told me that this mod from Tomcat is as simple as drilling out one valve (say from ø3mm to ø6mm) but can also lead to cooling problems of PAS oil, and might need a cooler. Not certain, but something along those lines. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted March 8, 2006 Share Posted March 8, 2006 A disco 2 box is proberbly the simplest way to go, allthough a gwagon box is almost definately stonger Quote Link to comment Share on other sites More sharing options...
