JackSA Posted May 20, 2009 Share Posted May 20, 2009 Hi guys, Looking to install an inverter in my Landy ... around 250W will do (not planning to arc weld in the middle of Botwana). Mainly to keep the laptop, sat phone and cameras topped up (maybe a small appliance). I've had a quick look around Maplin, and saw that familiar names, like Clark, not getting the best of reviews; so I'd like to hear from those in the field, please. Cheers for your time. -JackSA Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted May 20, 2009 Share Posted May 20, 2009 I would get something a bit bigger than 250w if I were you. I would recommend 500w for laptops, batteries & appliances. I was told to avoid the cheapy ones from Maplin/Halfords etc, and rather spend my money on industrial quality equipment. Mind you, mine will be used in an expedition vehicle, and if my inverter goes, then I am in a bit of bother! If you are only planning on using it on camping trips etc lasting a week or two, then I reckon one of the Ring ones from Halfords would suffice. HTH Martin Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 20, 2009 Share Posted May 20, 2009 250-300W for a laptop & various phone/iPod chargers should be plenty, a laptop will draw 100W at most and chargers draw naff all. Nowt really wrong with the Nikkai inverters from Maplins although sometimes they do the 600W one for the same price as the 300W one on special. Industrial spec inverters are nice but really un-necessary for most gear that has its own PSU or adapter. Could be easier to buy in-car chargers for most of those devices rather than convert 12v to 240v and back down to ~5v for most mobile stuff and ~15-20v for laptops. That way you're not reliant on the inverter to power everything. Quote Link to comment Share on other sites More sharing options...
51bigG Posted May 20, 2009 Share Posted May 20, 2009 Hi guys,Looking to install an inverter in my Landy ... around 250W will do (not planning to arc weld in the middle of Botwana). Mainly to keep the laptop, sat phone and cameras topped up (maybe a small appliance). I've had a quick look around Maplin, and saw that familiar names, like Clark, not getting the best of reviews; so I'd like to hear from those in the field, please. Cheers for your time. -JackSA Mine is 1800 watt, does everything I want, cant remember the name, Landy having clutch done so cant look. It allows me to run a small kettle, 110 transformer to run 5" angle grinder and various power tools, I have had to install a leisure batery as I am afraid to drain the cranking battery. Quote Link to comment Share on other sites More sharing options...
JackSA Posted May 21, 2009 Author Share Posted May 21, 2009 Hey guys, Cheers for the replies. some good advice there. -JackSA Quote Link to comment Share on other sites More sharing options...
RichardAllen Posted May 21, 2009 Share Posted May 21, 2009 Hey guys,Cheers for the replies. some good advice there. -JackSA I put in a 2kW Ring inverter. Fine 18months of regular use (incl hot air paint stripper for shrinkwrap) later. Regards Richard Quote Link to comment Share on other sites More sharing options...
