Disco V8 Bellhousing
Aragorn
 Share
I know this is a wanted ad, but i'm posting it here in the hope that someone might have one sitting around in a corner somewhere, or know of someone or somewhere selling it.
I'm trying to find a 300 series Disco V8 Bellhousing for my engine conversion. I currently have a 200 series housing, but its too long, and the 300 series housing being shorter will give me enough room to fit an adaptor plate between the box and engine.
I would prefer just the bellhousing, but would consider a complete box if its not silly money.
Anyone got anything laying around, or know somewhere that might have what i need?
Cheers
Well i need it as soon as possible really. I cant get the adaptor made until i have the shorter housing so i can accurately measure the thickness of the adaptor etc.
If you could have a look and see if you do have one, i'll see if i can sort out shipping.
Its not a particularly heavy item so shouldnt be too expensive.
hmm, whats it from?
the part number i need is FTC3922 (superseded by UNB100190)
What do you mean by its identical to a long stick box from a V8?
Afaik the FTC3922 was only fitted to R380-V8 equipped disco and RRC's
From my calculations it should be around 270-275mm long, compared with my current housing (FRC6154) which is around 300mm long.
The R380 housing is shorter becuase the R380 itself is 25-30mm longer than the LT77S
it's off a disco r380 i just took it off the gearbox :huh:
and what i should have said was its the same as the bellhousing from a r380 from a v8 defender ie a long stick box
hrc2642 is what is cast into the casing on the slave cylinder housing
hrc2642 is just a basic un machined casting number, not a LR part number
A V8 defender with an R380 isnt a standard box, its probably been crafted from a disco R380 with a defender tail housing.
It does sound like you have the right part though. Can you confirm its length for me?
Cheers
 Share
