Petes Posted June 1, 2009 Share Posted June 1, 2009 Does anyone know the correct part number for a 2001 td5 90 fuel pump. Vin is SALLDVA871A608*** There are a few WFX prefixed numbers and I want to make sure I get the correct one. Rgds Peter Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 1, 2009 Share Posted June 1, 2009 WFX000250 is one valid number, though there are various supercessions and I'm not sure what order they are in. The differences between the pump units are in the sender calibration - any "pump" will actually work with any Td5 be it 90/110/Discovery as they all run at 4 bar/58psi regardless of the age of Td5, but the fuel gauges will be screwed up if you fit the wrong one. Quote Link to comment Share on other sites More sharing options...
Petes Posted June 1, 2009 Author Share Posted June 1, 2009 yeah 250 looks to be the correct one cheers. Just priced one at the local dealer here in Australia.... 1737.50$ I dont think so!!! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 1, 2009 Share Posted June 1, 2009 If all you need is the pump you might be able to rip one out of a unit in a crashed vehicle at a scrapyard and rebuild yours with just the pump part? Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted June 1, 2009 Share Posted June 1, 2009 buy the Allmakes pump. it's a lot cheaper. the original LR one goes for about $800sgd here in SGP. i got the allmakes one from lrdirect.com at about the cost of $230SGD. Quote Link to comment Share on other sites More sharing options...
Petes Posted June 2, 2009 Author Share Posted June 2, 2009 Mine currently is fine, its just we are heading off across the Simpson Desert in late August so want to take a spare one just in case. Will just buy a genuine one from a different source. Not a fan of Allmakes stuff. (not that the genuine one is known for its reliability!) Loooks like I can get one landed for 500$ Quote Link to comment Share on other sites More sharing options...
Landy90man Posted June 3, 2009 Share Posted June 3, 2009 I have one taken from a 53 plate defender 90 £50 Quote Link to comment Share on other sites More sharing options...
surf110 Posted June 5, 2009 Share Posted June 5, 2009 WFX000250 is one valid number, though there are various supercessions and I'm not sure what order they are in. The differences between the pump units are in the sender calibration - any "pump" will actually work with any Td5 be it 90/110/Discovery as they all run at 4 bar/58psi regardless of the age of Td5, but the fuel gauges will be screwed up if you fit the wrong one. Can you change the sender calibration? I can get a WFX000260 for cheap but my 2000 Hi Cap 110 calls for WQB100420. Quote Link to comment Share on other sites More sharing options...
