StreetDragster Posted June 2, 2009 Share Posted June 2, 2009 Hi All Looking to replace the oil seal at the front of my transfer box, behind the flange which mates to the front prop shaft. It this a simple job? Any tips? I've done the rear diff pinion seal already, so i'm just wondering if its similar, do i have any spigots to pull out etc? Also, how do i check a universal joint for wear? Give it a waggle and look for play? Thanks Matt 1995 Discovery 1 300TDi 5 door Manual Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 2, 2009 Share Posted June 2, 2009 For the seal (ignore the bearing part, although it would be a good idea to change it as well) see: http://forums.lr4x4.com/index.php?showtopic=3315 http://forums.lr4x4.com/index.php?showtopic=23690 http://forums.lr4x4.com/index.php?showtopic=25053 For UJs, look for play, for stiffness and for rust around the seals. Give it a good shake in all directions on the vehicle (like a monkey shakes a tree to knock some fruits off) and also disconnect it from the diff/transfer case and wiggle it from the flange end. To replace the UJs see http://forums.lr4x4.com/index.php?showtopic=7982 Quote Link to comment Share on other sites More sharing options...
disco_al Posted June 2, 2009 Share Posted June 2, 2009 it may be worth getting a new output flange as well. they are only about £25, and as i discovered when i did mine on the v8, the flange had worn, which was why the seal had started leaking in the first place. IIRC they come with the seal as well. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 2, 2009 Share Posted June 2, 2009 That's what 'orange rover' learned the hard way, see the story in the 1st link I gave. Quote Link to comment Share on other sites More sharing options...
StreetDragster Posted June 2, 2009 Author Share Posted June 2, 2009 Perfect lads, thanks very much Matt Quote Link to comment Share on other sites More sharing options...
