alan kemp Posted June 5, 2009 Share Posted June 5, 2009 I need a new rose joint and bush for my SR adjustable panhard rod. Called in at SR last week but they are no more. I need to get hold of the rose joint which is not standard as it has wedges attached to the swivel ball. Any ideas where I can get one? Quote Link to comment Share on other sites More sharing options...
TOR4x4 Posted June 5, 2009 Share Posted June 5, 2009 The wedges are actually just spacers, you can get the rose joint from any decent bearing supplier. You should be able to remove the wedges and reuse them. Quote Link to comment Share on other sites More sharing options...
alan kemp Posted June 5, 2009 Author Share Posted June 5, 2009 The wedges are actually just spacers, you can get the rose joint from any decent bearing supplier. You should be able to remove the wedges and reuse them. I have tried to remove the wedges but they are well and truly siezed in. Quote Link to comment Share on other sites More sharing options...
Orange Posted June 5, 2009 Share Posted June 5, 2009 IIRC the SR stuff is a copy of the Equipe set-up isn't it?? That's what I've got on my 90 and it has the same set-up with the panhard rod... Quote Link to comment Share on other sites More sharing options...
alan kemp Posted June 14, 2009 Author Share Posted June 14, 2009 IIRC the SR stuff is a copy of the Equipe set-up isn't it?? That's what I've got on my 90 and it has the same set-up with the panhard rod... Left a message with LRS but so far no reply, perhaps Derick is on holiday. Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted June 14, 2009 Share Posted June 14, 2009 Got my rose joints from Erics, cost about a tenner. The same as my old scorpion item except no grease nipple. Erics Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted June 14, 2009 Share Posted June 14, 2009 Eriks part# for this item is "LDK POS 20" Quote Link to comment Share on other sites More sharing options...
alan kemp Posted June 15, 2009 Author Share Posted June 15, 2009 Eriks part# for this item is "LDK POS 20" Thanks Adrian, they are not on the website but are getting back to me with price and availability. Quote Link to comment Share on other sites More sharing options...
alan kemp Posted June 18, 2009 Author Share Posted June 18, 2009 Thanks for the link Adrian, Erics were very quick to respond, the joints arrived yesterday, £15.00 each (no discount) plus delivery. I had to cut the old one in half to retrieve the spacer bushes. Quote Link to comment Share on other sites More sharing options...
