rockyrock Posted June 10, 2009 Share Posted June 10, 2009 hi all I have a 94 discovery v8 3.9 es. I aquired it recently and it failed the mot on emissions, it was running really rich. I found that the problem was the hose between the air flow meter and the plenum. The end had been hacked off and there was no seal. After buying a new hose i found that the reason the old one had been hacked was because of the gas conversion. Between the hose and plenum a collar has been added ( i believe it contains a venturi for the lpg to mix with the air) this collar makes the hose too long so when connected the hose is severely kinked. does anyone know of a after market hose that will fit correctly or any other solution. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted June 11, 2009 Share Posted June 11, 2009 This is a common problem with venturi type LPG systems,I've never seen a shorter hose,most either get forced on and kink,or they get trimmed.Its not easy to move the airbox/AFM either.Seems you are on your own with a solution. Quote Link to comment Share on other sites More sharing options...
pw8757 Posted June 11, 2009 Share Posted June 11, 2009 My LPG setup was like this, although I didn't seem to have the problem described. Actually the solution I adopted, as part of getting the vehicle running more efficiently on LPG was to fit (amongst other things) a different air filter, which was supplied by the excellent RPI but which looks suspiciously like a Range Rover Classic air filter. If you PM me I will get a picture to you over the weekend. Quote Link to comment Share on other sites More sharing options...
audiman Posted June 12, 2009 Share Posted June 12, 2009 my v8 3.9 0n a 95 is fitted with lpg but its got a K&N air filter induction filter on it dont seem to have any hose problems cheers lee Quote Link to comment Share on other sites More sharing options...
rockyrock Posted June 12, 2009 Author Share Posted June 12, 2009 thanks all, looks like i will be changing the air filter, It is probably the best solution Quote Link to comment Share on other sites More sharing options...
