bernie Posted June 15, 2009 Share Posted June 15, 2009 I have a 300 tdi 110, one of the long bolts which go into the engine block at the base of the waterpump has sheared off, can i get away with forgetting this bolt, and put pump back on, or replace, which means alot more work stripping it all down. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted June 15, 2009 Share Posted June 15, 2009 You could give it a try but i think it will proberly leak, only way to find out is to try.......but if it were me i would try to fix it been as its a very important part to go wrong. Dave. Quote Link to comment Share on other sites More sharing options...
bernie Posted June 15, 2009 Author Share Posted June 15, 2009 You could give it a try but i think it will proberly leak, only way to find out is to try.......but if it were me i would try to fix it been as its a very important part to go wrong.Dave. I was thinking that, I know that really i need to replace bolt, Oh well more work. Quote Link to comment Share on other sites More sharing options...
bernie Posted June 15, 2009 Author Share Posted June 15, 2009 Once i removed the alloy bit behind the pump, broken bolt came out easily, bolt was corroded to alloy bit behind pump, whats the name for the alloy bit that the pump is bolted to. Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2009 Share Posted June 15, 2009 attaches to item 5 on this diagram Quote Link to comment Share on other sites More sharing options...
bernie Posted June 17, 2009 Author Share Posted June 17, 2009 Waterpump replaced, inlet manifold gasket replaced at same time,(better access) as it had been leaking, No leaks that i can see. job done and finished. Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2009 Share Posted June 17, 2009 we like jobs that end well. Quote Link to comment Share on other sites More sharing options...
