john01473 Posted June 16, 2009 Share Posted June 16, 2009 Please, can anyone tell me if this could be true? I was told that I have leaky - Injector Return Hoses or would they be overflow pipes. Is this a job I can do – limited knowledge and ability as disabled. Any ideas of part numbers etc or cost if garage did it. Cheers all Big John Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 16, 2009 Share Posted June 16, 2009 It's dead easy to change them. No tools required. All you need is to be able to reach the top of the engine and have two valid fingers Pull each end of the old hoses and push back the new ones. There are 3 hoses connecting the 4 injectors. Here's where they are on the engine (the middle one is behind the black cylinder): Here for the part # or other suggestions and pictures (you need only the hoses): http://forums.lr4x4.com/index.php?showtopic=28947 http://www.thexmod.com/item_detail.asp?id=1103 Quote Link to comment Share on other sites More sharing options...
Riverside Posted June 16, 2009 Share Posted June 16, 2009 Try a good motor factor or commercial vehicle spares place. The DAF dealership where I used to work sold it by the metre a lot cheaper than buying JLR originals! Cheers, Bill Quote Link to comment Share on other sites More sharing options...
freeagent Posted June 17, 2009 Share Posted June 17, 2009 yep, buy a metre of it from your lovcal motor factors. Make sure the engine is cold when you do it, and worst case you might need a stanley knife to split the old hoses as they can be a bugger to pull off... its a 10 minute job. Quote Link to comment Share on other sites More sharing options...
denviks Posted June 17, 2009 Share Posted June 17, 2009 its a 10 minute job. and thats witha cuppa in the middle Quote Link to comment Share on other sites More sharing options...
disco_al Posted June 17, 2009 Share Posted June 17, 2009 standard 3.2mm fuel hose, gates part # 3225-10050 about £2.50/metre Quote Link to comment Share on other sites More sharing options...
