Steve King Posted June 20, 2009 Share Posted June 20, 2009 Are All Makes hinges any good or should I stick to genuine LR ones? Cheers Steve Quote Link to comment Share on other sites More sharing options...
tychoS Posted June 20, 2009 Share Posted June 20, 2009 Are All Makes hinges any good or should I stick to genuine LR ones?Cheers Steve I have recently bought both genuine and britpart. Those from britpart arrived "pre-worn" so to speak. They had something like 20 degrees of play from the factory. That's far more play than the old and worn hinges they were supposed to have replaced. If you buy genuine, consider the TD5 version even if you have an earlier model, since they rotate on a plastic bush rather than metal against metal. Quote Link to comment Share on other sites More sharing options...
kkk2 Posted June 21, 2009 Share Posted June 21, 2009 I have recently bought both genuine and britpart. Those from britpart arrived "pre-worn" so to speak. They had something like 20 degrees of play from the factory. That's far more play than the old and worn hinges they were supposed to have replaced. If you buy genuine, consider the TD5 version even if you have an earlier model, since they rotate on a plastic bush rather than metal against metal. I agree, when we bought a truck last year the guy selling it threw in a set of door hinges from Britpart, when we went to fit them they were worse that the ones on the landrover. Quote Link to comment Share on other sites More sharing options...
ChrisM_110 Posted June 22, 2009 Share Posted June 22, 2009 Or if you're a cheapskate, do what I did. Buy some crappy Britpart ones, hammer the pins out, notch them a smidge, and slap in two nylon wahers. Tightens them up and helps the wearing. Quote Link to comment Share on other sites More sharing options...
rallycinq Posted June 23, 2009 Share Posted June 23, 2009 Mine need a refurb too, woillowing the earlier thread Going to need to take them off and i am guessing that the rusty screws holding them on is not a good sign. I have been spraying them with plus gas every week for a month and will get stainless ones before attempting. Cheers David Quote Link to comment Share on other sites More sharing options...
