keithjh Posted August 20, 2005 Share Posted August 20, 2005 Hi All, The better half has decided that i need something to do over the winter anyway fancy a Rapier to convert to camper etc, so the questions are? 1, anyone know the internal measurements of the rear body? 2, is there access via hatch/door etc from front cab? 3, were they all fitted with the V8 as standard? 4, is the roof strong enough for a rack with ezi-awn on? i`m sure there will be many more questions when i find one but thats it for now just trying to get an idea if the back will be as large as i need. Regards Keith Quote Link to comment Share on other sites More sharing options...
white90 Posted August 20, 2005 Share Posted August 20, 2005 you need to consult Miserableolgit Quote Link to comment Share on other sites More sharing options...
western Posted August 21, 2005 Share Posted August 21, 2005 All Rapier tractors were V8's and full soft tops including the cab, there is no panel work above the cab waist line, so you ill have to bulid your own uppr body structure to suit your requirements. Quote Link to comment Share on other sites More sharing options...
