Reng Posted June 30, 2009 Share Posted June 30, 2009 I have found the manifold on my Disco TD5 is warped and the end studs are snapped or pulled out. I have contact a repair center who will do the work of ensuring it is fixed and true agin. My only question is, do you replace only the affected studs or all of them as a matter of course? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 30, 2009 Share Posted June 30, 2009 studs cost absolutely nothing so i'd just replace them all Quote Link to comment Share on other sites More sharing options...
AJL Posted June 30, 2009 Share Posted June 30, 2009 Heres the fix (pics of my manifold a few years back when i had the same problem) http://www.oec4x4.com/index.php?option=com...3&Itemid=42 James Quote Link to comment Share on other sites More sharing options...
ciderman Posted June 30, 2009 Share Posted June 30, 2009 Top tip there from OEC , After having your manifold checked for straightness and maybee skimmed ,Loose the webs , They dont allow for expansion and cause the studs to shear off . Always fit new studs even if they look ok , It piece of mind . Quote Link to comment Share on other sites More sharing options...
Reng Posted July 2, 2009 Author Share Posted July 2, 2009 Top tip there from OEC , After having your manifold checked for straightness and maybee skimmed ,Loose the webs , They dont allow for expansion and cause the studs to shear off . Always fit new studs even if they look ok , It piece of mind . Thanks for the replies - It has now been sorted and all is well Quote Link to comment Share on other sites More sharing options...
