Bluemoon Posted June 30, 2009 Share Posted June 30, 2009 I've been reading how to tune the injection pump, (300tdi), but not sure how or if its necessary to boost the turbo , read something but thought it might be for the 200tdi, can anyone point me in the right direction, cheers Brian Quote Link to comment Share on other sites More sharing options...
western Posted June 30, 2009 Share Posted June 30, 2009 this should help. http://forums.lr4x4.com/index.php?showtopic=31 from our tech archive engine section. Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted June 30, 2009 Author Share Posted June 30, 2009 that was the article I read, so is the turbo, " best left alone", for a 300tdi, apart from the pipe to the inlet manifold Brian Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted June 30, 2009 Share Posted June 30, 2009 Yes, as a 300tdi is already boosting at 1bar, but the 200tdi is boosting at 0.7bar which is why that generally needs turning up. Tune your pump untill its powerfull but not smokey. Remember, you may fail your emissions test on the MOT, so be prepared to turn it back down for the mot, which means write down the orginal position of the smoke screw and star wheel etc. Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted July 1, 2009 Author Share Posted July 1, 2009 cheers, looking forward to see what its like Brian Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 1, 2009 Share Posted July 1, 2009 I'd be winding it up anyway. 18psi should give everything a nice boost. Quote Link to comment Share on other sites More sharing options...
