kevin31031961 Posted July 1, 2009 Share Posted July 1, 2009 Yet again my wonderful Disco 03 auto has a problem but as you guys are stunning and have saved me a fortune i thought you may help, .oil sump plugs leaking? dont know which one but they shall we say are they both have washes on but still leaking ......................how do i stop ? and will i have to drain the sump first.{ of course i will what am i thinking }.............is it common ? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 1, 2009 Share Posted July 1, 2009 Are the washers new/the right size? Les. Quote Link to comment Share on other sites More sharing options...
kevin31031961 Posted July 3, 2009 Author Share Posted July 3, 2009 Are the washers new/the right size?Les. Dont know Les , had service done by land rover dealer so i suppose they should be why? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 3, 2009 Share Posted July 3, 2009 A leak at a sump plug is either poor seal (copper washer), grit between the seal somewhere, or stripped thread. Les Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 3, 2009 Share Posted July 3, 2009 Or as mine was, the fact that some numpty drilled and tapped the hole crooked when it was made, meaning that the plug didn't seal all the way around the mating face and it leaked Quote Link to comment Share on other sites More sharing options...
JST Posted July 3, 2009 Share Posted July 3, 2009 why not buy another sump plug and sealing washer, remove old and replace before the oil drains out or change them when its next due a service. If its just been changed (oil that is) did they do them tight enough. Which one are you talking about anyway engine, auto box or T box? Quote Link to comment Share on other sites More sharing options...
kevin31031961 Posted July 5, 2009 Author Share Posted July 5, 2009 Auto box they have said all new washes but have tried to tighten but still leaks ? they are now not interested strange dont you think Quote Link to comment Share on other sites More sharing options...
