dirtbox Posted July 1, 2009 Share Posted July 1, 2009 Hi all. Real quickie as off out but desperate for help! After nearly 2 months of problems i thought I'd had it sorted untill I realised my slave cylinder is leaking like a good-un! Basically, what is the difference between the V8 slave cylinder and the 4 cylinder one? I have the V8 clutch fitted but with 4 cylinder set up if that makes sense. Anyway, thanks in advance as I could do with buying one tomorrow. Cheers guys Paul Quote Link to comment Share on other sites More sharing options...
western Posted July 1, 2009 Share Posted July 1, 2009 don't know what the difference is, but it could be the bore diameter & movement of the piston/push rod. Quote Link to comment Share on other sites More sharing options...
dirtbox Posted July 1, 2009 Author Share Posted July 1, 2009 Cheers western. Thought that the length of forward push would probably be the difference but cant see how that would make any difference with the slave cylinder. All I can think is its designed to handle the difference between the increase in pressure that the V8 cover plate would make.???? I have already have had a clutch centre rip out within 100 miles with my diesel conversion and I don't fancy having any more problems that could be sorted ASAP, hence my concern regarding the slave! Thanks again peeps! Quote Link to comment Share on other sites More sharing options...
