wytco0 Posted July 26, 2009 Share Posted July 26, 2009 Hi I am looking to replace mine even though they seem OK because rather than sealing the doors and preventing water getting in they seem to act like sponges and fill up with water which then pours into the car when I move it. Are their any improved seals available? Also I need the bottom rubber seal for the back door as mine is split. Thanks. Quote Link to comment Share on other sites More sharing options...
wytco0 Posted July 27, 2009 Author Share Posted July 27, 2009 Hi I am looking to replace mine even though they seem OK because rather than sealing the doors and preventing water getting in they seem to act like sponges and fill up with water which then pours into the car when I move it.Are their any improved seals available? Also I need the bottom rubber seal for the back door as mine is split. Thanks. HI Just to add a bit for clarification to this, its the part numbers for the rubber door surrounds that I am after. Any advice on how to stop the water that pours in would also be appreciated, I have done what it suggests in the water ingress manual but I still get the waterfall down the inside of the passengers door when I start to move after rain. Its annoying and its alread susted the bottom of the door. Quote Link to comment Share on other sites More sharing options...
T1G UP Posted July 27, 2009 Share Posted July 27, 2009 DON'T buy the bearmach ones......carp. Genuine only if you require half a sealed door Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2009 Share Posted July 27, 2009 tail door lower floor seal ALR4770 LH front door seal CFE102980 RH front --------- CFE102990 Quote Link to comment Share on other sites More sharing options...
wytco0 Posted July 28, 2009 Author Share Posted July 28, 2009 Thanks western Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2009 Share Posted July 28, 2009 happy to help Quote Link to comment Share on other sites More sharing options...
